Brief Description: Wired GP circuits for trim & flaps.
The positioning of the sensor D-sub9 connector took a while to locate. I finally zip tied it to the bottom of the avionics fan after running the cables up the left firewall angle stiffener and making a service loop. I also used a little double stick tape between the fan housing and connector. You must locate the connectors with the realization of lying on your back under the panel and looking up and back. That's why the label is on the bottom of the connector.
Wiring the connector was tedious while crimping the pins onto the tiny wires. Felt like my fingers were all thumbs.
D-sub mounted to bottom of avionics fan.
Looking up from below, the connector is zip tied to the fan housing.
The aileron connector wired but not yet in its final position.
