Brief Description: Finished wiring the E-bus Alt Feed Relay.
Today I finished wiring the E-Bus Alternate Feed Relay. I used a 10AWG wire from the Aux battery which is about 4' long to the Com terminal of the relay. The normally open (NO) terminal on the relay was wired with about 8" of the 10AWG wire to the E-Bus fuse block (hence the alt. feed instead of the Main Bat. The 10AWG wire may be a bit overkill but there will be very little voltage drop to the E-Bus and I could later add more of a load if necessary. The E-Bus load is a max of 14.71 amps but the relay is rated for 20 amps.
The E-Bus Alternate Feed Relay is engaged by a switch on the switch subpanel which switches to the FW ground giving a path for the circuit from the Aux battery.
10AWG wires to the E-Bus Alt Feed Relay and E-Bus fuse block.
E-Bus Alt Feed is switched by black wire which goes up to middle rib then down to ground block on FW.
