Greg's RV-12 Classic N719VA
Date:  4-2-2022
Number of Hours:  1.50
Manual Reference:  12-11
Brief Description:  open talcone fairing hole
Manual 12-11, opened the bottom clearance hole in the tailcone fairing for clearance with the trim servo assembly linkage.
Removed more protective plastic from the wings.
Tested Dremel timing bit for use on the flaperons for clearance to the fuselage.
