Greg's RV-12 Classic N719VA
RV-12
Remove stabilator and reglue washers
Removed the stabilator and re-glued the washers. Temperature was warm enough to perform this work. Stabilator is supported on the lift as the counterweight stays in the fuselage.
Remove more plastic protective sheeting.
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
