Greg's RV-12 Classic N719VA
RV-12
31B
corrected trim servo wiring
Manual 31B-04 Swapped the two white wires in the trim servo connector from the fuselage. This was done to correct the movement of the trim servo. Used the Molex microFit extraction tool.
Also tested FlyQ to Dynon wifi connection.
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
