Greg's RV-12 Classic N719VA
Date:  9-2-2021
Number of Hours:  2.75
Manual Reference:  49
Brief Description:  finish cowl heat shield foil, install oil hose
Manual 49-16 finish step 4, cut foil heat shield #4 and applied to cowl. Applied epoxy resin mix around the foil edges.
Manual 49-17 step 5 install oil hose VA-215, ned to rearrange due to improper fit and clearance.
