Greg's RV-12 Classic N719VA
Date:  6-23-2021
Number of Hours:  7.50
Manual Reference:  38-05
Brief Description:  attach mid cowl hinges, trim pins, sand to fit
Manual 38-05 steps 1 - 7 attach mid-cowl hinges to bottom cowling. Trim pins for fit. Lots of sanding of the bottom cowl to make fit properly, test fit, sand again, and again. Had to remove so much on the left side to align the cowl properly with the prop hub that I filled two holes already drilled with epoxy and flox to redrill.
