Greg's RV-12 Classic N719VA
RV-12
46 45A
torque engine mount, install master relay, wiring
Manual 46-05 step 6 - torque the engine mount bolts to 29.5 ft./lbs. Unable to torque left rear bolt due to clearanve not adequate for allen wrench to fit properly. Taped it with note.
Manual 45A-02 - step 6 install master relay torque bolts to 70 in/lbs.
Manual 45A-03 steps 1-3, connect power cables to battery and chassis mount.
master relay
power wires
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
