We brushed epoxy resin mix onto the duct tape on the aircraft and laid the fiberglass in place. The left aft edge of the fairing was sticking up a little because of the cardboard template screw-up. I had cut the template too close and added a small strip to the edge. This edge did not lie flat when the duct tape was placed over it and so the fiberglass did not lie properly either. Jeff placed a strip of duct tape over the area in an attempt to pull it down. A small strip of tape was placed on the underside of the long piece of tape so the tape would not stick to the fiberglass.
The right side of the fairing
The left side with the duct tape placed over the aft edge
