Brief Description: Photos 3-Right and Center Areas of the Fairing
After the fairing was laid in place. Jeff and I used the glue brushes and acid brushes to push out the bubbles. The right side was placed in the proper area along the bottom, but we did not check the left side as the fiberglass was laid in place. The left side ended up a little short on the side. I pushed the center area into and around the center rail as tightly as possible.
