Baker's RV-6
Date:  12-3-2013
Number of Hours:  3.00
Brief Description:  Swapped CB's/Pitot Heat Wire/Panel Put Together
With all of the CB's removed, the new 3-amp CB's were put into position and the wires were screwed to the CB's. All CB's were inserted back into the panel. The Dynon EMS-120 bracket was reinserted into the panel. The wire bundle was reattached to the bracket. The glovebox was reinstalled to the panel. The EMS-120 was reinstalled in the panel.
The P-1-0 connector had all of the wires unpinned from it. The connector will have the new wires for the AeroLed lights inserted into it.
The pitot heat power wire was run along the left side. A Molex pin was crimped onto the wire and then inserted into the P-1 connector. The pitot heat now works!
EMS-120, CB's, and glove box back into place
The old WigWag controller with the connector taken off
