Brief Description: Removed CB's from Panel/Removed Wig-Wag
I removed the second nut on the back of the bracket which released the wire bundle. The bracket was removed from the panel to allow better access to the circuit breaker panel. The map box, CO detector, and fresh air vent were unscrewed to allow more access. The taxi and landing light CB's will be changed out. They are in the middle of the third row of the CB panel.
The first CB was removed and the second had its wires unscrewed. The taxi and landing light CB's were also unscrewed from the bus bar and the wires. They were then removed. A few hours were spent attempting to screw the wires onto the replacement CB's. George Gilby suggested removing the nuts on all of the CB's and pushing all of the CB's behind the panel, which would allow better access to the new CB's. This was done.
The wig-wag controller was removed from the panel.
Wires and circuit breakers in the third row removed
