The three switches for the wigwag, landing and taxi lights were removed from the panel. The two black wires screwed onto each of the light switches were removed. Two new black 20 ga wires were cut to be run from the switches to the P-1-0 connector. One wire had a ring terminal crimped to it, which was then screwed onto the taxi light switch. The second wire had a short wire added to the ring terminal on it. The short wire also had a ring terminal crimped on it. These two ring terminals were screwed onto the wigwag and landing light switches, The two wires were then labeled.
