The wires from the 37-pin plug on the Dynon EMS-120 were run through the hole in the instrument sub-panel, except for the EMS Serial Plug. This resulted in 26 wires running through the sub-panel that needed to be marked. Using the Brother label-maker, I marked almost all of the wires and applied heat-shrink over the labels.
