I received another Aircraft Spruce order, which included a Plane Power 60 amp alternator and more hardware. I also received the Robbins Wing carb heat muff that I had ordered.
I installed the Plane Power alternator bracket onto the engine and safetied the bolts. The alternator was bolted in place. In order to install the belt, I had to loosen the starter and lower it to open the space between it and the ring gear. After I pulled the belt into place, I tightened up the starter.
The carb heat muff was installed on the front exhaust pipe from the right cylinders. It was installed just like the cabin heat muff.
The PlanePower 60 amp alternator
The PlanePower (left) and Van's (right) alternators
