Baker's RV-6
Date:  11-16-2010
Number of Hours:  4.00
Brief Description:  Cleaned up Bench/Primer Plugs/Drilled Top Skin
I spent a lot of time cleaning up the workbench and putting hardware away.
I screwed the AN913-1 brass plugs into the primer holes. I applied Permatex Anti-Seize to the threads before the plugs were screwed and tightened. These plugs need to be safetied after the baffles have been installed.
I drilled #40 holes in the leading edge of the forward top skin and deburred the holes. I also deburred the #30 holes in the ribs forward of the instrument panel.
An AN913-1 brass plug and the Permatex Anti-Seize to be screwed into a primer plug
One hardware cabinet with some new labeling
Another hardware cabinet with new labeling
