Brief Description: More Trimming of the Left Wing Root Fairing
The left wing root fairing had to have a fairly sharp bend put into it to match the leading edge of the wing. A metal pipe with about a two-inch diameter was used to put the bend into the fairing.
The fairing still needed more trimming. This was a case of trim a little and then check the fairing in place. Mark another area for trimming and work on that.
The leading edge ready for trimming and the leading edge bend put in place
The left side needs to be trimmed about 1/16"
The fairing next to the fuselage. More trimming needed
