Brief Description: Trimmed Edge of Left Wing Root Fairing
The left wing root fairing was marked for trimming to match the fuselage contour. The fairing was clamped to the workbench. Jeff's die grinder with a sander attached to it was used to remove large amounts of material. A file was used on the small areas that needed to be trimmed. The Scotchbrite wheel in the die grinder was used to clean up the edges.
The fairing marked for trimming. The line across the fairing is for line-up reference
