Cleaned edges of right outboard top skin and left leading edge skin w/die grinder. Used Scotchbrite pad on inside surfaces. Drilled counterbalance rod to inboard nose rib and riveted rod to nose ribs. Found that aileron spar was warped. Have to drill out pop rivets.
