Drilled right aileron nose ribs to doubler and spar. Riveted doublers and nose ribs to spar. Drilled tip ribs to right spar. Drilled 3/16" holes in all 4 aileron brackets. Drilled aileron brackets to right spar, doublers, and tip ribs. Drilled counterbalance rod to outboard nose rib.
