Brief Description: Riveted Trim Cable Nut onto Access Panel
The bracket and doubler were drilled and riveted to the elevator access panel. The nut was then screwed onto the trim cable. The access panel was screwed to the elevator. The elevator was moved to check the trim movement and then the trim cable was moved thru the full range of motion. No problems were noted.
