Brief Description: Installed the rudder stop on the VS
Emmet Starks positioned and drilled the plastic rudder stop to the underside of the bottom bracket on the VS rear spar. He made spacers for each of the 3/16'' bolts to go between the hinge brackets. I had purchased the rudder stop from Craig Vincent in CA. He built the maximum angle of rudder movement of 35° into the stop.
Rudder stop installed under himge brackets
Rudder stop with spacers between the hinge brackets
