The P7 connector was reassembled. The P7 connector halves were joined together and the smoke system was working. The Ident button is active when the Smoke System primary switch is in the Arm/On position and the Remote Switch is up. The smoke system pump will then only run when the ident button is pushed and turn off when the button is released. The pump will also run when the Remote Switch is in the Continuous position.
