Brief Description: Chased Wiring Problem-Smoke System Ident Button
After reassembling everything, the Ident button stopped turning the smoke system pump on. With Jeff Paden's help, we found that the heat solder crimp was intermittent and needed to be replaced. This crimp was on the blue wire coming from the smoke relay. The crimp was cut off and a new one installed. The Ident button now works properly!
The bad crimp
Testing the system prior to reassembling the P7 connectors
