Brief Description: Added Wire in Pilot Stick Grip for Smoke System
The jumper ground wires in the stick grip were removed with the soldering iron and replaced with one black wire between the two side buttons. A length of blue wire from the Smoking Airplanes Remote Button was cut and soldered onto the Ident button, replacing the ground wire. The wires from the stick grip had already been removed from the loom and then replaced, adding the blue wire. The blue smoke system wire was pinned with a Dsub pin and placed into the #21 pin spon in the P7.
The P7 end of the pilot stick grip wires
The pilot stick grip, reassembled and ready to go back on the stick
