Brief Description: Modified Pilot Stick Grip Wiring for Smoke System
The wiring in the pilot stick grip had to be checked to see why the fuse was blown when the Ident button was pushed. The grip was disassembled and compared to the Ray Allen drawing. The Aerotronics P7 drawing showed that separate ground wires were run from each button on the stick grip, but the Ray Allen drawing did not correlate to this. The stick grip was actually done per the Ray Allen drawing, with jumper wires going from ground to ground to ground, buttons 2, 3, and 4. I cut the ground wires off going to and from the Ident button and taped them together.
The original wiring with ground jumper wires
The ground wires cut apart
The wires with heat shrink are for the Ident button
