Brief Description: Soldered Zaon Data Wire into Garmin Wiring
The Garmin data wire was cut apart. The data wire from the Zaon was solder-crimped to the Garmin data wire. The new wire was pinned, as well as the other two wires that needed to be repinned. Heat-shrink was applied and the wires were reinserted into the 9-pin connector.
