Brief Description: Made Power Wires for Lightspeed Ignition
The Lightspeed power wire from the control box had a ring terminal crimped on it after the shield was pulled back. Another length of 18 AWG shielded wire was cut and routed thru the subpanel toward the battery. A ring terminal was crimped on the end by the circuit breakers after the shield was pulled back. The two power wires were screwed onto the electronic ignition circuit breaker. The two shields were spun together and heat shrink was applied over the shields.
The Lightspeed power wires screwed onto the circuit breaker
