Brief Description: Photo-Carb Heat Inlet/Air Inlet on Cowling
The smaller metal air inlet that will be installed in the cowling was laid on the cowling and the cowling was marked. This area will be ground out so that the inlet can be permanently installed.
Top view of the carb heat inlet and new glass
The air filter inlet marked for the metal ring
The metal air inlet ring that will be installed, but in the reverse position
