The safety wire that was wrapped around the oil temp sensor and the breather tube was cut off and a new safety wire installed on the sensor and the mechanical tach cap. The EGT and CHT wires on the right side were tie-wrapped to the ignition wires.
Dave looked at the safety wiring job and noticed that it was a bit loose. That will need to be redone.
