Brief Description: Riveted Right Rear Baffles Together
Cover pieces were cut out of .016 material to be riveted onto both sides of the right rear corner of the baffle pieces, in order to cover up the numerous holes drilled during multiple alignments of the baffles. The cover pieces were riveted together with the baffles.
The overlay of the two aft center baffle pieces was clamped to the reinforcement bracket and the three pieces were drilled to #12 size. A bolt was installed.
The right rear baffle
The right corner
The center rear reinforcement baffle bolted in place
