Brief Description: Wire Labels/Drilled out Rivets in Top Skin
I had received some clear heat-shrink from SteinAir and so I made more labels for wires. I then placed a length of clear heat-shrink over the label and used the heat gun to shrink it. I applied a short length of wire wrap to the caution/warning wires on the top of the instrument panel. These wires run under the center bracket and could vibrate into the bracket. This wrap should protect them. I applied some RTV around one of the warning lights on the instrument panel, in order to stabilize the light, because the hole was slightly oversized.
I noticed three rivets were being pulled in at the front of the top skin, so I drilled them out, inserted spacers and then reriveted them. Much better!
Wire wrap wrapped around the caution lights' wires
