Brief Description: Canopy Rollers/Clear Heat-Shrink over Labels
I applied more heat-shrink to the edges of some clear heat-shrink tubing over labels. Since the clear heat-shrink did not shrink down tightly onto the wires, I tried to get tighter heat-shrink to prevent the clear from moving. We'll see if this works.
Update: 3/8/10-Ordered 1/8'' clear heat-shrink from Stein Air.
I reviewed the canopy drawing again for the canopy rollers and found that I had the screws on the wrong side of the nylon rollers. I took the rollers apart and put the nylon rollers to the Scotchbrite wheel. This removed some material on the rollers so that the brass bushing, instead of the roller, is tight against the canopy roller.
