Brief Description: Primed Skin/Static Tubing Clip/Battery Bolts Space
I primed the aft top skin. I made a clip out of scrap .032 material and drilled and riveted it to the left longeron behind the baggage bulkhead. This clip will hold the static tubing in place. I measured and then cut two lengths of 3/16'' ID tube for the battery hold-down bolts.
Battery bracket bolted in place
Static tubing clip riveted in place on the left longeron
