Brief Description: Final Trim-Aft Top Skin/Added Transducers
I painted the F-6111 skin stiffeners. I took the aft top skin off again and did one last trim on the leading edge. I straightened the center 8'' on each side and reworked the arc. I screwed the oil and fuel transducers into the manifold, as well as the two fittings and brass plugs. I used EZ-Lube on the fittings.
The aft top skin after the final trimming
The F-111 stiffeners after painting
The oil and fuel transducers screwed into the manifold
