Brief Description: Cut Push-Pull Tube/Riveted Nut to Trim Access Pane
Measured and cut the push-pull tube to just about the proper length for final assembly. It might be 1/4" too long. I positioned and pop-riveted the nut onto the elevator trim access panel.
Nut riveted to trim access cover
Push-pull tube next to the elevator bellcrank and tube end
