Baker's RV-6
RV-6
Cut Elevator Control Rod/Wood Legs
Measured and cut F-690 control rod to proper length. Made wood legs for stabilizing the fuselage. These were screwed to the wood false spar.
Found that two holes for the trim cable need to be drilled in bulkheads F-604 and F-605.
Ordered 6061-T6 1''x1'' and 1 1/2''x1 1/2'' angle, fitting cap, and many cushioned clamps from Wick's.
Bernie Ockuly stopped by and dropped off all of his scrap material from his -7A, as well as a 4' stick of 1x1x1/8'' 6061-T6 angle.
Wood legs attached the false spar
Fuselage leveled to zero degrees along the longeron
Roll axis of fuselage leveled to zero degrees
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
