Continued to trim F-642 right seat floor skin along fuselage side. Drilled pilot holes for seat belt brackets and then used cut-off wheel to trim areas. Used files, Scotchbrite pads on die grinder, and Dremel tool with a sanding tip to round corners and smooth edges.
