Brief Description: Drilled F-642 Right Seat Floor to Ribs
Finished holes for seat belt brackets. Clecoed F-647R right baggage floor skin in place. With F-642 right seat floor skin clamped in place, drilled it to the rear spar and ribs. Used hole finder and #30 drill bit to drill holes along rear spar line. Some ribs needed to be nudged into alignment, so I used a door hook to grab the rib and pull it into position. Drilled all holes with #30 bit. Deburred all holes in F-642 and ribs. Drilled three holes along both inboard ribs and edges of seat floor skins.
