Brief Description: Installed air vents over the top of the NACA ducts
I finally got around to doing a little more on the plane, I have installed air vents from a Ford Transporter over the top of the NACA vents supplied in the kit. To seal the gap (the inlet of the truck vents has a 10mm larger radius than the NACA vent neck) I an going to glue some soft foam in place around hte NACA vent and then force the mouth of the Truck vent over the foam. The reason I have installed then under the dash is, 1. They are quite large and would take up far too much room in the dash and 2. Mounting them under the dash is not an option because I am 6' 1" and this would restrict my leg room, so this is for me, the next best spot, and yes I can still bend forward and adjust both vents. The eye ball is positionable and the amount of air flow can be adjusted using the center knob, so all in all, for about $4.00 for both vents I am very pleased.
Right side eyeball vent installed over the top of the NACA vent
Left side eyeball vent installed over the top of the NACA vent
