Well it came together fairly easily, I managed to get the step leg fairing to follow the contour of the bottom fairing qutie well, its all just been roughed out with the tin snips, so it still needs some filing and sanding etc. I am not quite sure yet if I will bother trying to fill the side section where you look into the bottom fairing ???
Right side fairing fitted, all the edges still need to be cleaned up
