Eddie's Zodiac XL Project
Date:  8-5-2006
Number of Hours:  4.00
Brief Description:  Rear spar supports and seat supports
After the front seats I started on the rear spar support brackets and the rear seat top and bottom side support bracket. This was quite easy as the skins are already pre-drilled and its just a matter of positioning and back drilling. With this installed I started on the rear bottom seat stiffener, this is a 40 thou piece of L angle that gets installed behind the bottom rear seat support, lots of holes here at A5 pitch 30, I forgot to takes a photo, will do that tomorrow.
Left rear spar support bracket
Right rear spar support bracket
