Brief Description: Engine mounts and longerons attached
The plans I have for the engine mounts appear to be out of date, they show different fittings for the top engine mounts to the ones supplied, also the engine mounts I have do not have the bolts welded in place which is no big deal, but it was just a little time consuming trying to relate the old drawings on where the bolt hole should be drilled to the parts I have. I finally took a guess which appears to be correct. The location for the top hole is 19mm down from the top and 10mm in from the side of the mount that does not have a flange. This places the bolt in the bottom inside corner of the mount. I will add some pictures, the ones below are only of the bottom mount which just requires a hole in the centre of the mount.
Engine mounts installed and longerons clamped in place
