Brief Description: Front wheel bottom bearing support
I'm not sure if you can see this in the drawing, but the bottom bearing support just comes pre-bent, but without the front and rear cut outs. I decided to get this over and done with. I cut the front hole out with a 2" hole saw and then cut off the overhanging bits and filed smooth. For the rear I used a step drill and centered the hole 30mm back from the bend to allow 20mm for the bolts that will be placed across the back anf up both sides as shown in the drawing.
