Eddie's Zodiac XL Project
Date:  4-15-2007
Number of Hours:  4.00
Brief Description:  Throttle controls
The two supports that are clecoed to the top gear channel have a nylon bearing pop riveted to one face and the torque tube actually rides on this to give a smoother movement, although having just painted the entire mechanism, its going to require a few revolutions to free things up again, that and a little teflon oil should do the trick. The two vertical arms clear the top of my clowing by about 3mm-5mm, things are getting pretty close. I am glad that this job is finially done, it was a real painful exercise.
Overall view of the dual throttle setup
