Eddie's Zodiac XL Project
Date:  5-7-2006
Brief Description:  Drilled nose skin and dimpled rear top skin
Spent a couple of hours this afternoon just drilling and dimpling. I drilled all of the nose skin holes out to #30 and the rear nose skin where it meets the main spar out to #20. Then with Anne-Maries help we lifted the rear top skin from the wing and dimpled all the holes with the #20 dimple die, I can't at the moment remember the actual size (5/16 I believe). It was a bit of a challange because it was just getting dark and the annoying little bush mossies where trying to suck us dry. Anyway we got it all done and have lifted it back onto the wing. Now I just need to run the pitot and static lines, coat the tops of the ribs with Cortec and insert the tie down ring and the rear skin can be riveted in place.
