Disassembled the entire HT, Dimpled the top skin. Dimpled the ribs and HT frame and coated surfaces with cortec corrosion inhibiter. THis is just visible in the photo as the white streak between the trailing end and the rear attach bracket. I am considering getting the Cortec tinted so that once it drys it remains visible as the supplied product dries to a clear finish.
