Marked HT rib ccenter lines, clamped and back drilled. Made a doubler for the rear HT attach bracket where I stuffed the radius when I mis-read the radius value. Measure up 17mm with radius 12mm. I translted this into 17mm up with radius 17mm. Probably still jet lagged after return from Abu Dhabi the previous day.
