Eddie's Zodiac XL Project
Date:  12-1-2007
Number of Hours:  6.00
Brief Description:  Installed side panels and carpet
I had four inserts made for the sidewalls of the fuselage (two each side of course), which really finishes the interior of the cockpit quite nicely. John Turner who did the upholstery did a fabulous job, and if you look closely at the two forward panels, you'll see that he also added some map pockets as well. He also provided some high density foam for the firewall the help deaden the noise and provide some insulation, the same material has been used as a backing for the side panels.
Right rear and forward side panels with carpet installed on the forward section, floor and firewall
Same for the left side
Carpet on the floor of the baggage area
