Eddie's Zodiac XL Project
Date: 11-22-2007
Number of Hours: 2.00
Brief Description: Left wing bottom leading edge painted yellow
This afternoon, the routine was heater on in the spray booth, wipe down the leading edge and then apply two light coats of yellow. If you look carefully at image one, you can just see a couple of dark marks, this is where I rubbed back the white paint down to the primer, the yellow does not cover very well, so when I turn the wing over the tip will get another couple of coats of paint to cover these properly. Oh by the way, the spray booth was devoid of flies this afternoon, but as soon as I had finished spraying, three large blow flies flew in as I walked out, I managed to evict them before they could do any damage, insect count so far, one small mosquito.
Outboard view of leading edge painted yellow
Another view
Inboard view
